1466 with hydraulic problem
Mario
01-11-2004 19:30:13
Have a 1466 that when I place the lever in the raise position it takes a while to start lifting. I also noticed that when I placed in the raise position and move the auxilary valve it raises perfectly. Please help me diagnosing the problem.
Thank You
Aces
01-12-2004 04:52:58
 Re: 1466 with hydraulic problem in reply to Mario, 01-11-2004 19:30:13
Mario The hydraulics on the 1466 has a load valve under the seat for the hitch and I would say the o ring or seat of the valve is bad. take the cover of that is below tthe seat and there will be a big plug behind the cover in the right hand seat support that is the load valve take it out and inspect it. Hope this helps.
Mario
01-12-2004 19:16:19
 Re: Re: 1466 with hydraulic problem in reply to Aces, 01-12-2004 04:52:58
Thank You Ace for writing back. Today I took the plug off and the little piston that goes inside. I cleaned real good and placed in back. I admit that the o-ring on the outside seem to be a little worn but I didn't replaced it because the dealership was closed. Anyway, after placing it all back the hydraulic system starting working great, but after lowering and lifting it a couple of times with excitment it started doing the same thing. I am thinking that if I replace the o-rings the problem might be solved. Once again I thank you.
Bernard le mécano
01-14-2004 18:28:52
 Re: Re: Re: 1466 with hydraulic problem in reply to Mario, 01-12-2004 19:16:19
Hi Mario, check on the load valve for a small orifice, may be this orifice is plugged. Blow air to remove dirt. Bernard le mécano Québec Canada
