H Swinging drawbar roller question?
John
01-13-2004 18:31:29
I am leaning towards getting a roller for my swinging drawbar for my H. I saw one in my owners manual that shows the roller being round shaped, I saw in the OEM Catalog the roller is round in the center but then is tapered. Can anybody give me some info on this? Has anyone ever gotten one from OEM? Thanks!!
John
01-15-2004 06:04:10
 Re: H Swinging drawbar roller question? in reply to John, 01-13-2004 18:31:29
Thanks guys!!! I will probably just get the strap because I won't be swinging it at all.
Hugh MacKay
01-14-2004 02:40:55
John: back when these tractors were new some came with each type of roller, as Bob said IH must have been using a couple of suppliers. I don't know as I would go to a roller unless doing a lot of work where you let it swing. Like Bob said if you are doing a lot of work with it pined in center or any given location the roller will go flat on one side. Probably the hardest thing on the roller is a hay baler.
I remember buying a new roller for 560, I decided to buy strap as well and just use roller during main tillage season. That wasn't the answer either. The strap and roller as well are two of those items, that once you get them tight you never loosen them for anything. The roller is the hard one to keep tight if changing these during seasons. One idea I saw on a farm was drawbar equiped with roller and he used a heavy U bolt up from bottom, thus removing weight from roller and clamping swinging drawbar tight to cross bar, while doing PTO work.
Farmer Bob
01-13-2004 19:10:18
I believe originally IH had a couple of different suppliers for the roller. One was just slightly larger diameter in the middle that it was on either end and the other style had a rather pronounced "Hump" in the middle of it which rolled nicely on the "U" shaped drawbar. Both worked just fine until continued use in one position wore a smooth area on it where it made contact with the u shaped drawbar. They also used just a heavy strap to support the swinging drawbar and hold it in place under the U shaped one.
