450 steering gear box
doug
01-14-2004 01:12:48
i have a farmall 450 and the steering gear box has alot of play in it is there any adjustment for this problem?(is there a adjusting screw like a truck would have)
Aces
01-14-2004 05:13:40
 Re: 450 steering gear box in reply to doug, 01-14-2004 01:12:48
No, you could have loose nut bad bearings, bad bushings bad gears you will have to look and see then fix.
doug
01-14-2004 05:57:47
 Re: Re: 450 steering gear box in reply to Aces, 01-14-2004 05:13:40
thanks for the advice aces
