SUPER M LP
LOYD
01-14-2004 07:08:01
I recently purchased a Super M LP serial # F 15466 C .I would like to know if this is a factory LP and how many were built .Also,is the battery located under the seat on this model? Any information would be appreciated.
robert hall
01-14-2004 17:04:26
 Re: SUPER M LP in reply to LOYD, 01-14-2004 07:08:01
I have a gas SM that is an early super m witht he rounded front instead of the boxy like front for cultivator mounts. Its serial # is 18360, so yours is probably an early super m or, as they have called it, a stage I super m.
John A
01-14-2004 16:36:09
LOYD, From what you have said about this tractor it is a Stage II Super M - LP.I assume it also has live hydraulics (pump is mounted in frount of the distributor). There is a resevoir under the tank. Many have 3 outlets to raise and lower Rh,Lh,& Rearmounted implements.
OBTW....There are Stage III SM. Technically...they are SMTAs, W/ LPTO...factory converted to LP. Has a long wise tank, Tank has a single multi valve, instead of a bunch of different valves in a row, like the conversion tanks. There were only 500 built.
Hope this helps,
John A.
NDS
01-14-2004 15:30:15
According to Guy Fay IH Tractor Data Book C suffix is for factory LPG N suffix is also LPG 2500 ft. and up.
Harold H
01-14-2004 13:58:57
Basicly, if the tank is crosswise it is a factory LPG, if the tank is longways it is a conversion, if it is Stage I without live hydraulics the battery is under the tank, if it is Stage II with live hydraulics the battery is under seat. I have not checked your serial number which would also show year for Stage I or Stage II. I just stated simplest difference to easly tell factory vs conversion LPG on Super M's and Stage I vs Stage II Super M's.
Harold H
Van
01-14-2004 22:21:53
 Re: Re: SUPER M LP in reply to Harold H, 01-14-2004 13:58:57
I am not sure on the cross wise, long wise theory of factory vs conversion tractors. I believe my Stage III to be factory and it has the long tank. I don't know.
Van
Harold H
01-15-2004 16:47:41
 Re: Re: Re: SUPER M LP in reply to Van, 01-14-2004 22:21:53
All factory SMLPG's had the crossways tank unless for some reason your tank was changed later on.
Harold H
LOYD
01-15-2004 09:28:22
THANKS TO EVERYONE WHO POSTED REPLIES TO MY QUESTIONS ON THE TRACTOR.I NEED TO ASK ONE MORE- HOW ARE THE STAGE I,II DEFINED ? BY SERIAL NUMBER?
LOYD
Loyd
01-14-2004 14:23:51
My tank is crosswise;tractor does not have live pto and the battery sits under the tank.The information is very helpful.Thank you.
Loyd
