806 hyd pump??
hagan
01-14-2004 17:18:05
when I take my 806 and run it and start off slowly the TA is slow to shift into direct and when I cramp the steering it will shift back into TA and when I straighten it out it will shift back into direct. I have a feeling it is the hand pump and it is getting weak.
the tractor vet
01-14-2004 18:40:54
 Re: 806 hyd pump?? in reply to hagan, 01-14-2004 17:18:05
Your mcv pump is not doing it's job , the pump could be wore out or it could be the pressure reg.and a bunch of weak springs in the mcv body . Run a pressure test and see just what ya have , i like to set them up to around 245 to 265 . Then there is the chance that you have a problem starting in the T/A where it is bypassen and that is why you don't have the flow and pressure that is needed to hold in high.
Rich
01-14-2004 18:01:22
Can be mcv pump week. Steering has priority over anything else. Could be week TA. Take a pressure test of your mcv.
