560 HYDRAULIC PROBLEM
PAUL
01-15-2004 05:37:02
I JUST REPLACED THE HYDRAULIC PUMP ON MY 560. AFTER STARTING THE TRACTOR THE ENGINE LUGGED DOWN AND HYDRAULICS SEEM TO BE AT HIGH PRESSURE. IF YOU PULL ONE OF THE HYDRAULIC LEVERS THE ENGINE RUNS FINE. WHEN STARTING THE TRACTOR YOU NEED TO PULL ONE OF THE LEVERS TO GET IT TO TURN OVER. SEEMS LIKE A VALVE IS STUCK???
RB
01-15-2004 09:58:32
 Re: 560 HYDRAULIC PROBLEM in reply to PAUL, 01-15-2004 05:37:02
Your 560 has stubs with flats on each side that point back toward the seat support, one for each valve, these are for changing from double to single action, sometimes these get turned to far and cause this condition. Also the linkage for the fast hitch, near the clutch pedal, can be misadjusted,unhooked or broken.
