Adjusting Spacing on 1066 WFE
Mitchissippi
01-15-2004 14:07:41
I need to narrow the front-end on my 1066. I have 3 holes showing, and I need to go to 2. I'd bet they haven't been moved since it sold new.
What's the best way to loosen up the tubes and tie rods?
I was told I should keep everything soaked with penetrating oil for a while, then loosen all the clamp bolts and drive it around a while.
Any suggestions?
Mitch
Hugh MacKay
01-17-2004 03:33:08
 Re: Adjusting Spacing on 1066 WFE in reply to Mitchissippi, 01-15-2004 14:07:41
Mitch: I doubt that a 1066 will be all that bad just yet. Most of the troublesome front ends I've run across have been set for close to 50 years. I think if you had some heat present for stand by, shouldn't be too much trouble. I would try it first anyhow. Driving around with those bolts loose on a Super A is one thing, that big tractor could shear a bolt.
If I were doing this I would pull all right out and lube them well. I always spray paint them with graphite inside and outside. You might want to move them again in 50 years.
