M W PISTONS
DAVE S
01-15-2004 16:05:24
Does M & W Gear Co. make pistons and sleeves any more? They use to make high compression pistons with ofset pins that took out a lot of the engine vibration. If so does anyone have a web address or phone # Thanks Dave
chad
01-16-2004 05:45:02
 Re: M W PISTONS in reply to DAVE S, 01-15-2004 16:05:24
I am prety sure a company bought them out. I found info a year or so ago on the web called up the number and and got new rings from my m&w pistons thay made the set to match the number on my piston. He also said they had pistons. I will try and dig up the number for you.
Chad
robert hall
01-15-2004 17:44:32
No, they are not in business since, I don't know the year, one of their plants burnt down and destroyed their blue prints. You should be able to find some if you look hard enough though.
hope that this helps.
robert
