farmall 300 -6 or 12 volt
abane
01-15-2004 19:30:53
I went to look at a 300 Farmall and the person that had the tractor was using a 12 volt battery to try starting it.Are they 6 or 12 volt and are they positive or negative ground.I have a 350 amd a 400 farmall and the 400 is negative ground , 12 volt and the 350 is positive ground, 12 volt and both are original.How can you tell if it is 6 or 12 volt?
Randy in NE
01-16-2004 04:12:18
 Re: farmall 300 -6 or 12 volt in reply to abane, 01-15-2004 19:30:53
You get 2 volts per cell. If it has 3 fill caps then it is 6 volt. 6 caps would be 12 volts.
abane
01-16-2004 04:29:39
 Re: Re: farmall 300 -6 or 12 volt in reply to Randy in NE, 01-16-2004 04:12:18
I understand what a 6 volt and a 12 volt battery is but the question was , how can you tell what the electrical system is on the tractor and if it is a pos or neg ground?It doesn't have a battery in it!!!!!
Van
01-16-2004 05:01:37
 Re: Re: Re: farmall 300 -6 or 12 volt in reply to abane, 01-16-2004 04:29:39
If its got the original generator I would bet that it is positive. A alternator would be negative ground. Also the coil should have the + terminal wire to the distubutor if it is positive ground and the - terminal if negative.\
Van
tractorboy
01-15-2004 20:39:03
All the 300's and 400's I've been around have been 12 volt,but I'm not sure on the ground, it's positive on the letter series.
Red Man
01-16-2004 12:45:59
 Re: Re: farmall 300 -6 or 12 volt in reply to tractorboy, 01-15-2004 20:39:03
All 300's and 400's came out with 6 volt positive ground. 12 volt was not available until 350 and 450 series. I have a 350 gas of which I am the second owner, and it is 6 volt positive ground. The 350 and 450 could be ordered either way. The 350 Diesel was 12 volt from the factory.
