W9 Stuck engine Head Gasket
novice
01-15-2004 21:52:15
I have purchased a W9 that is stuck. I have it up on blocks. I have taken the old junk tires off the rims and have hung weights on the rims with the tractor in gear with hopes they would turn the engine over in time (1/4 can PB Breakfree squirted in each cylinder). If she wont free up I will need to take the oilpan and head off and disconnect stuff to work her loose. If I do I plan to have the valves redone as I suspect the stack was not covered when she sat outside and they are rusted up. Will I be able to find head gaskets and seals for the valves???
42FarmallH
01-16-2004 11:05:50
 Re: W9 Stuck engine Head Gasket in reply to novice, 01-15-2004 21:52:15
Got my gasket set from a local parts house - Hedahl's. Check NAPA and others... Fel-Pro still makes the valve grind set...
John
01-16-2004 08:42:17
Right now on E Bay their is a head gasket up for auction for your model. Is new O.E.M
MD Wa.
01-16-2004 08:37:20
novice: Your IH dealer should have gasket sets, or be able to get one for you. Morgan
