smta trans pilot bearing #
paul
01-18-2004 04:41:27
Anyone have the oem or any part number for the transmission pilot roller bearing,only part I need to put this baby together would like to finish this project today.Thanks.Paul.
Aces
01-18-2004 09:24:53
 Re: smta trans pilot bearing # in reply to paul, 01-18-2004 04:41:27
Paul use to do that for a living so know how you feal.
rebuilder
01-18-2004 09:21:35
Paul:
Parts book shows 4 different part #'s. For tractors with serial #F-501-->F5267 & #L500001-->L512541 Three bearings are shown and says they can interchange. Part numbers in order in book are 43357DA/ 356624R91/ 69215DA. Book has what looks like manufacturer #'s listed behind the I.H. number, but if you need these post a line later.
For tractors serial #60001 and up I.H. bearing number is #359173R91. Just to make sure we are talking about the same thing; these are numbers for the transmission main shaft front roller bearing(goes into the T.A. output shaft). Also, in case you were not aware, use a rubber band to hold the rollers of the bearing in as you out the housings together. The rubber band is pushed back on the main shaft where it will not harm anything after helping in aligning the housings during reassembly.
paul
01-18-2004 16:38:51
 Re: Re: smta trans pilot bearing # in reply to rebuilder, 01-18-2004 09:21:35
Rebuilder,once again my hats off to you and no I was NOT aware of the need to use a rubberband to keep the rollers in thats why I need the part number.ACES clued me in on that little trick,thats me a day late and a dollar short.Thank you for the part numbers,the closest IH dealer is 30 miles away but have some luck with local parts store if you give them the # they usually have at their warehouse.Thanks again Paul.
