Question for Guy Fay or anyone else
Farmall-Nut
01-18-2004 07:05:58
Guy, I am restoring a SW6TAD, I know by the chassis serial plate it was the 233 SW6 made. I run into the problem when I try to research the engine serial #. The cast code dates its manufacturing at 12-23-53(engine). I know that there was no attempt to match the numbers but the engine serial number is not even in the sequence. That # is 8625. After pressure washing and blowing off old paint I found the original color to be yellow with a white primer. I then checked against the Trac-Tractors and still can't find an origin for the #. The engine is properly stamped with the D-264 so that ruled out other possibilities. Have you in your research found any info to help clear up this mystery. Thanks ED
STEVE
01-18-2004 11:16:23
 Re: Question for Guy Fay or anyone else in reply to Farmall-Nut, 01-18-2004 07:05:58
ARE YOU SURE THE8625 IS NOT THE PART NO OF THE BLOCK?
Farmall-Nut
01-19-2004 04:58:02
 Re: Re: Question for Guy Fay or anyone else in reply to STEVE, 01-18-2004 11:16:23
I am positive, Steve, The part # was cast into the block, not stamped.
Guy Fay
01-18-2004 10:02:30
D-264 engines were serial numbered sequentially, wether they were used in Farmalls, standard tractors, crawlers, power units, skid units, etc, as someone else mentioned. No relationship whatsoever with the tractor production numbers.
Dave WV
01-18-2004 07:27:38
Engine numbers for the 264 started with the first Supers like a SW6 so your number could be correct.
Farmall-Nut
01-18-2004 07:37:37
 Re: Re: Question for Guy Fay or anyone else in reply to Dave WV, 01-18-2004 07:27:38
Dave, That is true but the #'s started with 10001. I always thought the engine fell at least in the same sequence of #'s. Hows the weather up there. Ed D. in VA
Dave
01-18-2004 08:12:19
 Re: Re: Re: Question for Guy Fay or anyone else in reply to Farmall-Nut, 01-18-2004 07:37:37
May be wrong on this,I think D264 numbers started
at start of 264 engine production and carried on
whether engine was used in row crop or W series.
Someone on here will probably let us know.Snowing
now
Farmall-Nut
01-18-2004 08:52:55
 Re: Re: Re: Re: Question for Guy Fay or anyone els in reply to Dave, 01-18-2004 08:12:19
Do you still have the phone number of the guy who bought the 300 block? If you do will you send it to my e-mail I have a part I think he will need. ED
