farmall m brake job
ih4fun
01-18-2004 10:53:27
I had oil leaking from the brake shoe cover on my m, after i removed the cover i found the seal was leaking, i was removing the bolts in the bearing cover when i noticed the bearing retainer was broken, someone had tried to remove it and broke the retainer where the bolt hole for the puller goes,so i was unable to use the puller in fear i may break it again, useing wedges i have almost got it out but now it is stuck. does anyone have any ideas how to get it out?
SGT K
01-18-2004 12:39:28
 Re: farmall m brake job in reply to ih4fun, 01-18-2004 10:53:27
IT sounds like you are trying to pull the bull pinion assembly, which contains the seal. STOP The inner roller bearing flange will break off when it contacts the bull gear. I just went through the bull pinion assemblies on an H and some of the guys gave me a lot of good advice. Look under the posts titled END PLAY or END PLAY DISCOVERED. If you need something more post again. People are always eager to help, and I will share what little I know.
SGT K
STEVE
01-18-2004 11:04:30
YOU NEEDS TO GETS YOU BULLGEAR OUT OF THE WAY FROM THE INSIDE BEFORE IT CAN BE REMOVED
