Hydraulics, A or super A?
Dave A.
01-18-2004 12:34:49
Which tractor has the hydraulics the farmall A or super A? thanks for all you can tell me.the one I'm looking at has a blade front and rear.
Dave BN
01-18-2004 13:09:49
 Re: Hydraulics, A or super A? in reply to Dave A., 01-18-2004 12:34:49
The hydraulics on the Super A and later tractors were "lift all" type only. There never were 3pt or other type lifts or lines. Dave.
SAm in NS
01-18-2004 12:56:32
The Farmall Super A, Super A1, 100, 130 and 140 all came from the factory with hydraulics as standard equipment. The Farmall A was never equipped with hydraulics from the factory, however some have had them added by inventive individuals. Occasionaly a tractor is really a collection of parts from various tractors and if this happens you can have the serial number of a Farmall A with the motor and hydraulics of a Super A. The hydraulics on the later tractors run off a pump on the lower, front, right-hand corner of the block and the actual hydraulic unit is mounted under the gas tank. Hope this helps, SAm in NS
