farmall 100
jeeper
01-18-2004 16:13:24
looking at a 100 that has been sitting up inside of shed for about 10 years, tires and sheet metal and paint looks very good. owner has passed away. asking 1000 dollars ,dont no about running shape, does anyone know how meany h. p. it has. jeeper
Haas
01-18-2004 16:22:54
 Re: farmall 100 in reply to jeeper, 01-18-2004 16:13:24
If the tires are up and the engine is not stuck, and the block is not cracked in front of the carburetor, buy it. Also check the steering for play and look at the final drives and other castings for any cracks. Around 22 HP on the PTO. Also these things usually have some equipment such as cultivators, mower, plow, etc. so get that too.
old
01-18-2004 16:35:50
 Re: Re: farmall 100 in reply to Haas, 01-18-2004 16:22:54
My list says 20.10HP, sounds like it may not be to bad a buy as long as things that Haas has said are checked, I'd also look at the oil and antifreeze if it has any in it. Some times that can give you an idea about if it has run in the not to long ago past.
