JUMPING OUT OF GEAR
WILL
01-19-2004 04:34:58
hI ALL
I have an ih 454 that jumps out of gear quite often. You can be driving along and all of a sudden you stop moving, usually just dipping the clutch and letting it up agin will get you going but some times you have to shift the gear lever about, but it does not amways work. This tractos is fitted with a tourqe amplifier so dont know if its related and it does not work. The lever moves but nothinf happens.
all help appreciated
Greasy John
01-19-2004 07:19:05
 Re: JUMPING OUT OF GEAR in reply to WILL, 01-19-2004 04:34:58
One more reason I put the TA eliminator kit in my 350. Just to d$^@ many problems plus all that coasting in the steep country.sounds like all them little rollers got flat spots on 'em John
