Best plug for 300U
Brian S.
01-19-2004 05:41:35
Right now I have Autolite 388's in my tractor. What's the best, at least in your opinion, plug out there to give me the hottest spark. Also recommended gap. Need all the spark I can get in this cold weather to get her to fire!! Thanks.
RB
01-19-2004 07:09:29
 Re: Best plug for 300U in reply to Brian S., 01-19-2004 05:41:35
With more than 35 years working on farmalls I have found that Champion D18Y is a good plug for most conditions. The IGNITOR electronic ignition changeover helps starting significantly.
Brian S
01-19-2004 08:10:37
 Re: Re: Best plug for 300U in reply to RB, 01-19-2004 07:09:29
Thanks for the info. Can I purchase one of these replacement electronic ignition modules for my 300U?? Also just as a note, it has been converted to a 12 volt negative ground system.
Jerry in MI
01-19-2004 18:57:50
 Re: Re: Re: Best plug for 300U in reply to Brian S, 01-19-2004 08:10:37
Going off the top of my memory from Saturday, the gap I remember is .023. If you find some plugs that work better than Autolite, please post them. I am having a similar issue with my 300u.
smoknbs
01-20-2004 18:37:41
 Re: Re: Re: Re: Best plug for 300U in reply to Jerry in MI, 01-19-2004 18:57:50
the hotter version of the D18Y is the D 21 we have lots of luck with them up here near the Big Mac steve
