Rusted hand crank linkage - how to turn H motor by
Dave in CT
01-19-2004 17:42:51
Eventually I'll get the hand crank linkage on the front unstuck but, until then, how can I turn the motor on my H by hand?
Thanks,
Dave
earl in PA
01-22-2004 16:26:21
 Re: Rusted hand crank linkage - how to turn H moto in reply to Dave in CT, 01-19-2004 17:42:51
I just take my 450 out of gear and use a pipe wrench on the shaft sticking out of the belt pulley to slowly rotate the motor.
James Williams
01-20-2004 18:17:39
Dave,I just finished taking my crank completly out and freeing it up,I then reinstalled it ,however the crank would not line up with the crankshaft besaues the motor mounts had wore through the years.Most people dont relize this becaues they never use the crank.
Dave in CT
01-20-2004 19:59:01
 Re: Re: Rusted hand crank linkage - how to turn H in reply to James Williams, 01-20-2004 18:17:39
Did you have the motor out or the front wheels off when you did it? How did you get the linkage out? For me, the short cylinder with the teeth that catch onto the crankshaft pully (or its nut) is rusted solid to the hole in the transverse part of the frame in front of the motor. I was hoping penetrant and some banging would get it loose enough for me to rotate the motor but I'd like to borrow on your experience for getting at it. I just want to turn the motor to get at the release levers on the clutch and statically check the timing. The starter works fine. I'll use the other motor-rotating methods and wait for warmer weather if it's too involved.
Thanks,
Dave
James Williams
01-24-2004 06:59:49
 Re: Re: Re: Rusted hand crank linkage - how to tur in reply to Dave in CT, 01-20-2004 19:59:01
Dave,I had the bolster off,but with some penatrating oil and a large hammer it came loose,a lot eaiser than I thought
Haas
01-19-2004 18:14:51
If you are just wanting to turn the motor over and not start it, what I do is put the PTO in gear and then put a half of a PTO universal joint on the PTO shaft. Put a bar in the universal and you can turn the engine. Be double sure the ignition is off, probably best to take the coil wire loose to make absolutely sure it can't start.
Haas, also the belt pulle
01-19-2004 18:18:38
 Re: Re: Rusted hand crank linkage - how to turn H in reply to Haas, 01-19-2004 18:14:51
You can do the same thing with the belt pulley. It will be easier to turn since the gear ratio is more favorable than the PTO. All the same precautions apply.
49 Cubber!
01-19-2004 18:26:28
 Re: Re: Re: Rusted hand crank linkage - how to tur in reply to Haas, also the belt pulle, 01-19-2004 18:18:38
Oh does that bring back memeroies!My Grandfather used t ostart his H with the belt pulley.How he never got wrapped up in it Ill never know!!!!! !!!! Itried it once wit han H i use to have,NO WAY!I guess I just wasnt holding my moutn right!
old
01-19-2004 20:39:31
 Re: Re: Re: Re: Rusted hand crank linkage - how to in reply to 49 Cubber!, 01-19-2004 18:26:28
Not to put down Farmall or any thing but think about how old JDs are started, you turn the fylwheel not much differance from the belt pully. I have never been husr with my JD but have almost broke my arm with other tractors with hand cranks. By the way please no hate replays I have just about every color of old tractor there is I like them all, just wish I had the money to have at least 2 of every color
PUTTER
01-20-2004 06:57:54
 Re: Re: Re: Re: Re: Rusted hand crank linkage - ho in reply to old, 01-19-2004 20:39:31
Hey Old, I seen a guy start an old deere once by wrapping a rope around the flywheel then tying the other end to his pickup, just drove ahead and it took right off. PUTTER
Haas
01-19-2004 18:36:49
Well, certainly don't think it's a good idea to start them by hand that way. However, years ago, we used to start the MD by belting it up to the Super A. I recall my Uncle doing that several times, and never caused a problem.
JB
01-19-2004 19:10:53
 Re: Re: Re: Re: Re: Rusted hand crank linkage - ho in reply to 49 Cubber!, 01-19-2004 18:26:28
