Battery Cable
Ron
01-19-2004 17:48:04
What is the correct size battery cable to use on a farmall h.
Thanks Ron
GT
01-20-2004 13:53:55
 Re: Battery Cable in reply to Ron, 01-19-2004 17:48:04
Rewiring the battery on my 12V I went to the local welding supply and got the #2 I needed, to the inch, and they put the lugs on. It was very cheap.
klf
01-19-2004 19:02:01
I use 1/0 for everything, no matter what the voltage is.
Geoff NY
01-19-2004 18:42:45
Assuming that your H is 6volt 1 is good. If it's been converted to 12 volts 2 works. The lower the voltage the larger the wire gauge needs to be.
Larry in CO
01-19-2004 17:57:47
Ron,
I got mine at my local NAPA. These are part numbers for 1 guage cables.
711931 Battery to ground.
713531 Battery to starter switch.
714091 Starter switch to starter. 40" length.
Hope this helps.
Larry
