Anything wrong with the Farmall 450?
Will
01-20-2004 15:03:51
Anyone know of any particular problems with the Farmall 450LPG models? One has become available nearby and Im thinking of buying it. Tractor doesnt run, was told it needs a head gasket.
Thanks for the help. Will
49 Cubber!
01-20-2004 18:29:47
 Re: Anything wrong with the Farmall 450? in reply to Will , 01-20-2004 15:03:51
YES!Alot of problems,tranny is weak,engine is bad about getting stuck,burn alot of oil,propane draws the flies..... ..... ....Where did you ay you were from and where is this tractor?:)Good ole workhorse of a tractor.
Bill in Orono, MN
01-20-2004 16:45:56
Don't those "Pullers" drool over LP engine heads?
Sounds like a nice tractor-assuming it is all there.
Besides you can fill up the tractor and in addition to the hydraulic accessories you can run you can now run a bar-b-
que too!
Plowing and hot dogs...MMMMM hot dogs.
SuperCmore
01-20-2004 17:33:48
 Re: Re: Anything wrong with the Farmall 450? in reply to Bill in Orono, MN, 01-20-2004 16:45:56
They're good tractors but extremely ugly with the big tank blocking your view!! Cmore
Van
01-20-2004 18:11:39
 Re: Re: Re: Anything wrong with the Farmall 450? in reply to SuperCmore, 01-20-2004 17:33:48
That tank ain't ugly! If you are into LP its a beautiful sight and it smells great too. JD's are for cooking hotdogs on, grills are green you know.
Van
old
01-20-2004 16:40:38
From what I know about them they are pretty good I got one in the late summer but haven't put it to work yet. They have around 54HP
steveormary
01-20-2004 20:27:07
 Re: Re: Anything wrong with the Farmall 450? in reply to old, 01-20-2004 16:40:38
The gas burners will geet about 11 ft. to the gallon on a hard pull(chisel plow). Should be a good solid tractor for you.
