Vavle length in a 45 H
Digger
01-20-2004 16:58:28
I've repaced the valves in the head of my 1945 H The head is a high compression head 8043DB staped on the head. The old valves I pulled out were 5-3/8 so thats what I odered to put in. But I've been looking and the valves at other place say that after S# 106907 use the valves that are 5-15/32. What I'm asking in a around about way is this going effect my tractor or should I just leave the others in seeing that was the size in the tractor to start with?
Nebraska Cowman
01-20-2004 17:16:57
 Re: Vavle length in a 45 H in reply to Digger, 01-20-2004 16:58:28
if you put the long valves in that head you will have no tension on the valve springs and the tractor will not run smooth. I know, I've just bought one with that problem and now I get to take the head back off and do it right.
