Farmall F-20 or Regular
Luke from KS
01-20-2004 18:42:05
I am interested in restoring a tractor that I have. The only problem is that I don't know if it's a Farmall Regular or an F-20 as the serial plate is missing. The transmission is a 3-speed, characteristic of a Regular, it has side exhaust, family believes it to be a 1929 Regular but the number on the frame rail is 92376-either a 1930 Regular or a 1938 F-20. My question is this-Is there a way externally to tell the F-20 from the Regular? The tractor has enclosed steering gears, a reserve gas tank inside of main one (I think) the seat is an F-20 seat, it has the cable braking system, I have a bolt-on high-low gear for it and it rides on rubber tires with F-20 rims, but could have been changed over. It is to my understanding that Regular and F-20 parts are interchangeable. How do I know if it's a Regular or and F-20? This is frustrating for a sixteen-year-old! The paint is red and looks to be oringal, as it still has the bottom of the Farmall decals. This tractor has been cared for extremely will in its life and does not have one dent or flaw on it. It also has a Vortex air cleaner on it, if that helps, and all the casting numbers are 15-- DA or similar. Please help with any info you can give me! Thanks so much to all those who have contributed to my search.
Bill B
01-21-2004 14:20:30
 Re: Farmall F-20 or Regular in reply to Luke from KS, 01-20-2004 18:42:05
third party image
here is a photo of the steering differences. the one on the left is regular, the middle is the "duck bill" regular, and the one on the right is a f20.
Luke
01-21-2004 18:32:21
 Re: Re: Farmall F-20 or Regular in reply to Bill B, 01-21-2004 14:20:30
Hey Bill, can you give me more info on the enclosed steering "duck-billed" Regular? I believe that's what I have. Thanks so much to all replies. They helped a lot!
Jeff
01-24-2004 19:05:17
 Re: Re: Re: Farmall F-20 or Regular in reply to Luke, 01-21-2004 18:32:21
That is an F-20 not a Duck bill regular the duck bills were on the early F-20 and F-30 only
Bill Smith
01-21-2004 09:08:40
F-20 has enclosed steering gears, internal reserve gas tank, updraft carb, out the hood exhaust, 4 speed tranny, serial number on rear of frame rail and right side engine block, early ones originally gray, and later ones originally red. The regular has open steering gears, external reserve gas tank, down draft carb, out the side exhaust (no hole in hood for exhaust), 3 speed tranny, serial number on frame rail in front of radiator, and originally gray with red wheel's. Alot of parts will interchange, alot of tractors have scrambled up parts, alot of tractors have been repainted. You will have to look at the big picture. Sounds like you have some items on yours from both tractors. It's just a matter of figuring out what has been swapped out. One other thing, the later F-20's from 38 on (I think) had a V belt and not a flat belt for the fan. Hope this helps.
Nebraska Cowman
01-21-2004 03:34:01
The number on the frame rail. Regular numbers will start with T and be up front by the radiator. F20 numbers start with FA (ecept for a few TA built in 34) and the number is toward the rear of the frame rail.
randy hall
01-20-2004 21:41:42
it sounds to me like you have a regular that sometime had the steering gear changed to the much better enclosed worm gear setup. all f-20's had four speeds, but you could get different ratios after rubber tires became an option. on all regulars the rear axle was smooth on top. on all but a very few the f-20's rear axle housing has a lump near the top on each side.
Yoda, The (F-20 nearly br
01-20-2004 20:58:22
The enclosed upper bolster ie worm and sector makes me think its an F-20. F-20s had 3 speed trannys that were standard equipment. I believe the road gear was an option. The best way to tell them appart externally is the Regular has open steering gears as the 20 was worm and sector.
