Weight of Farmall A?
Larry Kastens
01-20-2004 18:56:37
What is the approximate weight of a Farmall A, without fluid in the tires? I realize it will depend on the size of the tires.
Thanks. I appreciate all the individuals who are helping me restore a Farmall A through your suggestions.
Haas
01-21-2004 05:46:51
 Re: Weight of Farmall A? in reply to Larry Kastens, 01-20-2004 18:56:37
Fay's data book says 1870 lbs. I suppose that is stripped without optional equipment. rear wheel weights are 145 lbs each, front wheel weights are 45 lbs each. fluid in the tires will add another 200 plus lbs per tire depending on the tire size.
Larry Kastens
01-21-2004 08:53:38
 Re: Re: Weight of Farmall A? in reply to Haas, 01-21-2004 05:46:51
Thanks to all. What is Fay's data book?
haas
01-21-2004 12:55:45
 Re: Re: Re: Weight of Farmall A? in reply to Larry Kastens, 01-21-2004 08:53:38
"International Harvester Tractor Data Book" by Guy Fay. Specification info on all the IH tractor from 1939 to 1959. You can get a copy from Binder Books, or Classic motorbooks.
kurt (mi)
01-21-2004 03:09:28
I think a Farmall A weighs in at about 2000LBS. give or take a little, I remember reading on this site that a guy said 1870 and he may have been to the letter.
tractorboy
01-20-2004 19:50:35
An A will weigh about 2,000 pounds, give or take a little, depends on how equipped: weights, lift, etc.
