Oil/Grease seal for Farmall A
Tom Lehman
01-21-2004 07:46:45
I am restoring a 1945 A. As I broke the diff. apart to replace the brakes, I noticed a small amount of oil leakage. In my book, the seal is called 'differential ball bearing retainer oil seal'.#46282 D. I've checked all the usual sources for this seal, cannot find it. Any ideas?
Haas
01-21-2004 12:51:22
 Re: Oil/Grease seal for Farmall A in reply to Tom Lehman, 01-21-2004 07:46:45
The differential seal is National number 410060 SSR, or IH number 288864 R93. While you are in there, might as well replace the final drive seal too. That will require removal of the brake drum, which is not a hard job. It is National number 410083 or IH number 71597 C91. These are the latest IH numbers, as I just replaced these on a 1948 Shop mule, which is the same as the Super A. I think these seals are the same for the A through 140. I also suggest you replace the gasket on the retainer cover for the pinion gear/shaft. That gasket is IH 1342398 C1. If you replace the final drive seal, easiest to remove the pinion shaft/gear and bearing, which requires removing the retainer/cover over the end of the shaft and likely after 50 plus years, the gasket is shot.
Brad
01-21-2004 10:27:53
I get my seals from the CaseIH dealer but if you get the Chicago Rawhide product number you can also get them from NAPA. The modern seals are a lot different from the originals but apparently last longer and work better.
lee
01-21-2004 09:10:02
That should be avalable from Case IH.
