International 2500-B transmission problems?
Jerry
01-21-2004 22:57:14
I have an International 2500-B with hydrostatic transmission. When the transmission gets warmed up with use, it stops moving. There is no forward or reverse until the transmission cools off. The transmission doesn't get "hot" just reasonably warm. Any suggestions on what to look
Michael Soldan
01-22-2004 17:59:20
 Re: International 2500-B transmission problems? in reply to Jerry, 01-21-2004 22:57:14
We always recommend a fluid and filter change to start with, this is the cheapest way to find out if anything more serious is wrong. Does the fluid have a smell to it and darkened colour? Many transmissions are messed when someone gets stuck and shifts back and forth for too long trying to rock the vehicle out. Does the fluid look foamy when it stops moving? There are products that drag racers use to keep trans fluid from foaming(NAPA Carquest PepBoys) getting better drive and shift patterns. I cant' be more specific, but wish you luck...Mike in Exeter Ontario
