560 ta
ryan
01-22-2004 10:28:47
bought a 560d a couple of months ago when you pull the ta handle back it doesn't shift down to low it stays in the high side ta cluch froze up or is ta bad thanks
Ernie Bob
01-22-2004 22:31:35
 Re: 560 ta in reply to ryan, 01-22-2004 10:28:47
Could be that someone welded the planted gears to the carrier to eliminate the TA. I found this on my 400 when I tore into it to replace. Lucky enough I had another TA to turn in as a core.
RB
01-22-2004 11:15:27
Yes, the TA clutch is probably stuck agsinst the flywheel. Remove the 4 bolt cover and first check the operation of the linkage, if you can see that the pressure plate is releasing you can use some WD40 spraying the disc and the spline. Also I've seen the pins come out of the pressure plate fingers. Good luck!
ryan
01-22-2004 11:45:56
 Re: Re: 560 ta in reply to RB, 01-22-2004 11:15:27
thanks for the info
farmer jim
01-22-2004 17:19:26
 Re: Re: Re: 560 ta in reply to ryan, 01-22-2004 11:45:56
when the ta is out . you will pull it back and it will stop moving
