Order Farmall Cub Parts Online
Cub/Cub-lowboy
farmallman
01-25-2004 10:48:39
Is there a difference between a Cub and a Cub Lowboy???
Thanks
Harold H
01-25-2004 12:26:44
 Re: Cub/Cub-lowboy in reply to farmallman, 01-25-2004 10:48:39
Look further down this same page. There is already a thread running on this that will help you. Basicly they are same basic tractor with final drives rotated 90 degrees on Lo Boy and lower front axle which make the overall height lower. Some other differences but those are most reconazable.
Harold H
George Willer
01-25-2004 14:32:16
 Re: Re: Cub/Cub-lowboy in reply to Harold H, 01-25-2004 12:26:44
Harold,
You're right, but if read wrong some might get the impression the final drives are interchangeable. They are NOT!
old
01-25-2004 12:00:15
Well from what I know about them which isn't much the cub was a little tractor that was painted red and is older the the cub low boy which was painted yellow and had a kolor engine. Hope this helps some
