fast hitch plow
max adams
01-25-2004 16:55:05
what i have is,is a 3-14 fast hitch square beam
plow. would anybody know the model? and i will be getting a 4 bottom this spring also and was wondering what model it might be as well? very simular but in the rear it has a hydraulic tail wheel i guess i'm not sure exactly what part it plays, but i know one of you guys know. thanks in advance,max
steveormary
01-25-2004 21:24:10
 Re: fast hitch plow in reply to max adams, 01-25-2004 16:55:05
Your hydraulic tail wheel is part of the lift assist system. Pushes down on the tailwheel to help support plow when lift arms are in raised position
Hugh MacKay
01-25-2004 18:48:39
Max: The 3x14 could be a couple of different models, 43 or 311. With hydraulic tail wheel could be 312 and 412, 3 and 4 respectively also 540. There may be others as my parts book has someitems missing.
Hugh MacKay
01-26-2004 08:42:08
 Re: Re: fast hitch plow in reply to Hugh MacKay, 01-25-2004 18:48:39
Max: Of those I listed 311 was the most common fully mounted fast hitch 3 bottom plow. The one I suspect you are looking at with hydraulic tail wheel would be the 412. From the parts book I would say it is not steerable tail wheel but just a caster tail wheel. The 540 will be steerable with a tie rod to the hitch.
This parts book I have has a lot of models mentioned, someone has removed the info on several models but left the index. The 510 and 210 just have the index pages left. Hold on, I just found another 3 bottom fast hitch plow, model is 309. The pull bar on the 309 has two different part numbers for 14" bottoms 526 171 R91 and 526 157 R91. This is made like 3 point pull bar with fast hitch forks welded at each end.
The 311 has two separate fast hitch forks bolted to plow frame, two part numbers for each side, and it calls them long coupling beam and short coupling beam. The short ones are left side 524 473 R11, right side 524 474 R11. The long ones are left side 526 343 R11 and right side 526 344 R11. This section covers both the 211 and 311 plows 2 and 3 bottom so I would expect the long ones are used on the 3 bottom plow, giving more support for extra weight. If you need anymore e mail me, then I don't need to stay on line while I type and look up items. Hope this helps.
max adams
01-26-2004 06:49:48
THANKS HUGH AND STEVE FOR THE INFO.NOW HUGH HOW DOES ONE DETERMINE THE MODEL?,ANY FEATURES THAT I CAN GO BUY?I'M NOT TRYING TO SOUND SILLY,JUST WONDERING.I KNOW IT'S NOT A 540,I HAVE TWO OF THESE.I WOULD LIKE TO GET MANUALS FOR THESE IF I COULD.AGAIN THANK YOU GUYS!
Hugh MacKay
01-26-2004 08:51:31
 Re: Re: Re: fast hitch plow in reply to max adams, 01-26-2004 06:49:48
Max: Take a look at my latest post, I placed it wrong, guess I better take a break, now posting to myself. It has some part numbers for you. If you need any more, e mail me.
