300 Runs Riiiich, carb parts
Bill in Orono,
01-25-2004 18:48:27
Hello,
Ok, I've been through the IH owners manual and the I&T. My Farmall is running rich. Black/brown exhaust, drips fuel on shut off--about two tablespoons. If ran ok prior to me fiddling with it. I messed with the idle mix and stop screws and the main adjusting screw.
Enough background.
Is the adjustment of the main adjustment screw enough to have it run rich? I know the manual says the screw should be out 5 turns but will it burn rich at that setting?
Lastly, my idle adjustment screws and main adjustment screws are quite banged up. Places on the web don't seem to carry these parts. Any suggestions?
Thanks.
Ray in Pa.
01-25-2004 21:00:28
 Re: 300 Runs Riiiich, carb parts in reply to Bill in Orono, MN, 01-25-2004 18:48:27
Bill, I think that 5 turns out on the main jet adjusting screw is too rich. After 10 years of experimenting with adjustments, I have found that on my Farmall 300, my tractor runs best with the main adjusting screw set about 2 to 2 1/2 turns out. I have discovered that anything more than 3 turns out will cause spark plug fouling and poor gas milage with no increase of power. My tractor also runs best with the idle jet adjusting screw set at 1 turn out. Setting the idle jet adjusting screw more than 1 turn out will bring on spark plug fouling also, and increase fuel consumption. Setting the idle jet adjustment less than 3/4 turn out, will cause the tractor to be harder starting due too lean adjustment, run poorly, cause hesitation and lack of power. The idle jet adjustment is very sensitive with as little as 1/4 turn when its near its best running setting.
Thanks Ray in Pa.
