jumps out of gear
will
01-26-2004 04:37:53
hI ALL
I have an ih 454 that jumps out of gear quite often. You can be driving along and all of a sudden you stop moving, usually just dipping the clutch and letting it up agin will get you going but some times you have to shift the gear lever about, but it does not amways work. This tractos is fitted with a tourqe amplifier so dont know if its related and it does not work. The lever moves but nothinf happens.
all help appreciated
scotc
01-29-2004 21:07:17
 Re: jumps out of gear in reply to will, 01-26-2004 04:37:53
does it jump out of all gears or just one gear? If its just one gear could be a tranny problem and not the torque.
JB
01-26-2004 19:08:18
Hi, does it only jump out of gear in LO TA ?
My brother has a 684D with TA and it recently started doing the same thing in LO TA, especially if there is a downward slope. The 454 and 684 have same rear end.
I think it is replace TA time or leave it HI TA all the time.
If you decide to replace TA let me know if that fixed the problem.
JB
parts man
01-26-2004 16:10:34
If some times all you have to do is disengage and re-engage the clutch, I would say that would have to be a TA problem.
