Over-running Coupler-- buy IHC or generic??
Darren in TN
01-26-2004 10:44:27
Hey, y'all.
I'm about to buy an ORC for my SA (alphabet soup!)-- should I go plop down the dollars at my local Case-IH dealer, or would a generic TSC or eBay ORC be just as good? There are some for around $30 on eBay right now.
Thanks,
Darren
GT
01-26-2004 14:02:20
 Re: Over-running Coupler-- buy IHC or generic?? in reply to Darren in TN, 01-26-2004 10:44:27
OK Guys I got one for my '56 400. Did I need to? I just did because it's better safe than sorry.
Hugh MacKay
01-26-2004 15:28:26
 Re: Re: Over-running Coupler-- buy IHC or generic? in reply to GT, 01-26-2004 14:02:20
GT: You really don't need these with live or independant PTO. Read Bob's post below. If you want to use it it can't hurt anything other than wear in the ORC itself. I have never used one however I suspect the higher the hp the more trouble they will be. I doubt if they will even stand much over 50 hp.
GT
01-27-2004 05:56:17
 Re: Re: Re: Over-running Coupler-- buy IHC or gene in reply to Hugh MacKay, 01-26-2004 15:28:26
Thanks Hugh, I suppose a little overkill is better than thinking I might run into my house. I could have used the length when I finally got a new PTO shaft for my mower. I just took it to Drive Shaft King and got it shortened a little.
James Williams
01-26-2004 12:32:26
Ive had the same one on my fergerson for 5 years.the only thing that has gone wrong is I sheares the pin inside of it,you need to keep a extra pin in your tool box
Thanks, Hugh and Pete!
01-26-2004 12:03:32
That's exactly what I was hoping to hear. Man, you guys are great.
Darren
Bill in Orono, MN
01-26-2004 11:19:54
Does a 300 farmall need an ORC?
Bob
01-26-2004 12:49:07
 Re: Re: Over-running Coupler-- buy IHC or generic? in reply to Bill in Orono, MN, 01-26-2004 11:19:54
Don't think a 300 needs one, as it's got live PTO. The purpose of the ORC is to keep the spinning blade of a bush hog or some other PTO driven device with lot's of rotational energy from pushing your tractor when you want, or need to stop quickly. Older tractors without live PTO have the transmission and PTO operating from the same clutch, so pushing the clutch in doesn't disconnect the stored energy in your implement from your drive wheels. The ORC is like a ratchet wrench in that it will transmit power (in one direction) to your implement, but not transmit power from the implement to the tractor. It can be very dangerous to operate a non-live PTO tractor without an ORC.
Hugh MacKay
01-26-2004 11:14:57
Darren: Those ORC's I'll bet are all made by 1 or 2 manufacturers, and I rather doubt CaseIH is one of them.
PeteNY
01-26-2004 11:11:21
Darren, Don't know that IH makes their own. The Case dealer I work for simply buys 'em from Tractor Supply, and then marks 'em up. Even if you find some with official IH or Ford, or JD...markings, they're still gonna be what ya buy at TS, or from Tisco...I think they are $65 bucks at our parts dept. Pete
