Decals and where to put 'em
Bill in Orono,
01-26-2004 11:28:21
Any one have a diagram or other help to lend on where decals go on a 300 Farmall.
I have:
Open with little arrow
BDO-for headlights-I got this one figured out
Gear Shift pattern
Caution 6V electrical sys
Hitch only to drawbar or front pull hook.....
Gasoline-where exactly?
Stop engine before shifting seasonal disconnect
Oil Filter-I got this figured out 2.
Be careful pressure cooling system remove cap slowly
Be careful do not make short turns at high speeds..... etc.
Be careful Stop power take-off before dismounting from tractor
Thats what I have. Any help or pics will be appreciated.
CNKS
01-26-2004 18:12:27
 Re: Decals and where to put 'em in reply to Bill in Orono, MN, 01-26-2004 11:28:21
Buy Guy Fays' new hundred series tractor book, just getting to book stores and internet places such as Amazon and Barnes and Noble. The book gives EXACT factory locations.
Paul G. in Mn
01-26-2004 17:46:47
Bill
If you find out were they all go would you let me know. I am going to be painting a 300 this spring and also am trying to find out were they go. Thanks Paul
Nebraska Cowman
01-26-2004 17:11:20
try to find old advertising pics and copy them. if in doubt, leave it off! One of my pet peeves is the "oil level" sticker that comes with some of the older sets. it is for the aircleaner can on the early tractors that does not have the embossed can with the oil level line on it. lots of those stickers end up on the oil pan where they do NOT belong.
Farmallkid
01-26-2004 15:59:39
The sticker placement on an M and a 300 could be the same or maybe different,i am not sure,have never seen a restored 300. So here is were some of them are on my M
Shift pattern--On the left side of light bar on the flat steel,or on the left top of the tank,i have seen both.
6 volt--don't have a sticker like that,but would assume it would go on the battery box.
Hitch only to--back half of left fender
gas sticker--on the side of the gas cap
power take-off--goes on the pto shield.I have the big black and yellow sticker.
That is what i know,the ones i left out are the ones i don't no.Hope this helps.
Hoppy
01-27-2004 06:03:35
 Re: Re: Decals and where to put 'em in reply to Farmallkid, 01-26-2004 15:59:39
If you buy quality decals from K&K they will be right to the year and instructions where to place them. K&K Antique Tractors 5995 N. 100W Shelbyville, In. 46176 317-398-9883
