f 30
bob
01-26-2004 19:28:31
any one have info on the f 30?weight,h.p.and width.thanks, bob
David Bacon
01-31-2004 21:14:17
 Re: f 30 in reply to bob, 01-26-2004 19:28:31
Bob if you have 28" rims you will stay wide --if you have 40 " rims? or 36" rims they can hang inwards over your final drive thus allowing the rims to be turned inward. I hope this can help you out. Dave NE iowa
F-Dean
01-27-2004 19:30:59
Found my Guy Fay book! Weight = 5,300 pounds. HP = 20.27 Drawbar & 30.29 PTO/Belt. Width = 89.25 with Rears in and 97.5 with Rears out.
bob
01-28-2004 05:06:05
 Re: Re: f 30 in reply to F-Dean, 01-27-2004 19:30:59
thanks all for the info on the f-30,i knew they were wide,but not that wide.guess i would need a wider trailor. bob
F-Dean
01-28-2004 06:06:35
 Re: Re: Re: f 30 in reply to bob, 01-28-2004 05:06:05
Depending how often you are going to haul it, you could take the wheels off and slide it on the trailer on the housings for the Bull-Gears. Roll the wheels on first and fasten then to the side of the engine after you have the tractor loaded. You can use the weight of the wheels to help balance your load. I have hauled several F-20s that I have purchased this way.
Bill Evans
01-27-2004 09:25:01
I mispelled the link in the first post. It should be: Link
F-Dean
01-27-2004 07:06:21
Guy Fay's book which is available at Tractor Supply (TSC) has all this information on a F-30 and the other early Farmalls
Bill Evans
01-27-2004 04:20:55
Go to our web site: www.oldoakfamalls.com. You'll find info on many IH models, plus a page featuring our F-30. If you need more info, email my brother Mike.
dan
01-27-2004 08:32:29
 Re: Re: f 30 in reply to Bill Evans, 01-27-2004 04:20:55
tried to go to your page and it does work, what am I doing wrong.
Bill Evans
01-27-2004 09:22:52
 Re: Re: Re: f 30 in reply to dan , 01-27-2004 08:32:29
Sorry about that. I mispelled the link. Try this: Link
Jeff
01-29-2004 19:01:43
 Re: Re: Re: Re: f 30 in reply to Bill Evans, 01-27-2004 09:22:52
What year are the F-30 that you guys have i have a 1936 /1932 and a 1931 with ser FB 687 the 1936 is a narrow tread
F-man
01-31-2004 10:18:07
 Re: Re: Re: Re: Re: f 30 in reply to Jeff, 01-29-2004 19:01:43
1937
