What part in the rear end makes the whining sound
Yoda the gearhe
01-26-2004 20:36:45
Some of my tractors make the whining sound in the rear end and others are quiet as a mouse. I was on an M today and it seams like the sound comes from the diff. Anyone ever rebiult one and made it quiet agian?
Dagger
01-27-2004 14:25:46
 Re: What part in the rear end makes the whining so in reply to Yoda the gearhead jedi, 01-26-2004 20:36:45
The Whining on my '47 M emamates from worn gears in the belly pump.
Chuck's Repair
01-27-2004 10:41:43
If it is most noticable in 5Th gear at high idle then it is most likely that the ring gear and pinion are not adjusted correctly.
CNKS
01-27-2004 07:49:19
Don't know, the C, H, and M are relatively quite, unlike the A and B. 5th will make a mild humming sound. 4th is slightly noticable, the other 3 gears are relatively quiet. Likely most of the noise you hear is normal. You will know when something is wrong.
Farmer Bob
01-26-2004 21:57:26
The typical noise you hear is usually from the straight cut gears in the transmission. As they wear, the mess pattern changes over time allowing more noise with age and use.
Your Face?
01-26-2004 21:22:12
ha ha
01-27-2004 18:18:35
 Re: Re: What part in the rear end makes the whinin in reply to Your Face?, 01-26-2004 21:22:12
Ah, a comedian you are
ROFL
01-27-2004 08:20:34
took me awhile but I got it.
