52 farmall super c
John In Vermont
01-27-2004 11:08:19
My father bought this tractor brand new and i have owned it for 35 years, i have always worked on it myself and have always been able to figure out any problem until now, it keeps blowing the hydrulic pump seal and filling the crankcase with hydralic oil,any help would be greatly appreciated.
John in Vermont
01-28-2004 04:58:05
 Re: 52 farmall super c in reply to John In Vermont, 01-27-2004 11:08:19
Thank to everyone for there input, I wiil see what i can do to get it fixed. John
JLK
01-27-2004 18:33:26
Had the same problem---took the pump off and put all new o-rings in--I had no previous ex perience at this --did it 3 years ago -use it all the time --no leaks--less than 50 bucks repair
TDK
01-27-2004 14:41:01
Would it be possible to put a "speedy-sleeve" on the shaft? If so,contact to your nearest bearing supplier,they probably have what you need.It's much cheaper than a $500 pump!
scotty
01-27-2004 12:23:50
John, I believe the Super C has the same pump arrangement as my Super A. The helical gear that is driven by the govenor gear, which in turn drives the shaft going into your hydraulic pump has an o-ring on that shaft. The o-ring eventually wears a spot in that shaft allowing the hydraulic oil to pass into the crankcase via the timing cover. If you can find a nos shaft along with new o-rings I think that would solve the problem. Hope this helps. Case IH sells a rebuiuld kit for the touch control. Were in Vt? Im in East Wells Vt.
scotty
John in Vermont
01-28-2004 04:52:00
 Re: Re: 52 farmall super c in reply to scotty, 01-27-2004 12:23:50
i have put a couple of new seals in but keeps blowing by. I am up in Berkshire way up north Scotty. Thanks to everyone for the information on the pump, i will see what i can do with it. John
Peabody
01-27-2004 11:26:43
I have the exact same tractor. Is it physically "blowing" the seal? My first guess it that the pump shaft has become worn at the seal, allowing oil to pass by it.
James Williams
01-27-2004 11:48:25
 Re: Re: 52 farmall super c in reply to Peabody, 01-27-2004 11:26:43
I have a Farmall 200 with the same problem,a new pump is 500.Some one advertised a NOS pump for 325.00
