Farmal M Clutch
Hank
01-27-2004 15:23:24
The book says I have to split the tractor to install a new clutch in my 1948 M. The old gentleman down the road said all I have to do is remove the belly pump. Before I go to all the work of spliting it I wondered what some of you thought.
Thanks: Hank in Homer
Hank
01-28-2004 10:43:48
 Re: Farmal M Clutch in reply to Hank, 01-27-2004 15:23:24
Thanks for all the response. Can I tell if it is a 11 or 12 inch clutch from the bottom after I drop the pump?
Haas
01-28-2004 19:12:00
 Re: Re: Farmal M Clutch in reply to Hank, 01-28-2004 10:43:48
I would think you could see enough in there to measure and determine the diameter.
Haas
01-28-2004 06:54:52
If it is a 1948, it should have the 11 inch diameter clutch and you don't have to split to rework the clutch. It the flywheel needs work, you have to split it. I have a write up on how to do it based on my experience doing it a couple years back. For a first timer, definitely more than a 2 hour job. Send it to you if you will post your E mail.
Steve
01-29-2004 11:02:22
 Re: Re: Farmal M Clutch in reply to Haas, 01-28-2004 06:54:52
Haas, I too am getting ready to put a new clutch in my 1949 M. Could you please send me a copy of that write-up? Thanks!
Jim
01-27-2004 16:37:31
Had to split my 52 M to replace the clutch since it has the 12 inch clutch.
49 Cubber!
01-27-2004 16:22:13
Unless you need to have the flywheel resurfaced,you dont have to slpit it.I have changed out several clutches with out splitting it.Took only a couple of hours as I recall.
moonlite
01-27-2004 15:52:11
I had rather split tractor. I have a good hoist and a lot of blocks and also this old man dislikes working on my back under the tractor. I guess it just depends on what kind of shop and how good you feel. Split tractor = more time work from bottom = harder work
TDK
01-27-2004 15:28:49
If it has 11" clutch it can be removed through belly pump opening.Have removed mine this way,sure beats splitting tractor.
