M Hydraulic GPM
Lesieg
01-27-2004 18:18:48
I was wondering what the GPM on an "M"'s belly pump is. I can't seem to locate this spec anywhere. Mine is not a super or anything , just a regular Farmall "M". Thanks in advance.
42FarmallH
01-27-2004 18:33:54
 Re: M Hydraulic GPM in reply to Lesieg, 01-27-2004 18:18:48
I have never found a definitive answer, but I know the live pump on the Super H/300/350 was around 9 gpm while Super M/MTA/400/450 was around 12 gpm - both were around 1200 psi.
As for the belly pumps I believe they are around 6 to 8 gallons per minute with the early pumps limited to 450 psi and later pumps at 800 psi.
Hope this helps...
