Torque Amplifier
Max(ia)
01-27-2004 19:40:46
Seems as if alot of the TA's in IH tractors are in need of rebuild. Is this a major project? Does the tractor have to be broken in half to accomplish the task? I know there are plenty of experts on here, so thanks for any info Max
Greasy john
01-27-2004 20:44:22
 Re: Torque Amplifier in reply to Max(ia), 01-27-2004 19:40:46
Hi Max---Sorry about the name mixup guys. Just CRS creeping up this old guy.
Greasy John
01-27-2004 20:39:58
Hi Kelly--yep you have to bust her at the eng-clutch joint and if things are messed up on the output end split her there too. I just did the job on my Landfill 350 (Pun Intended.)Mine was so bad I would have only been able to salvage the bolts and TA clutch cross shaft. Was quoted almost 700 bucks at 2 places so I went back together with the TA eliminator which makes it a straight thru 5 speed trans for 350.And like it better. Good luck on it.
Todd in NC
01-28-2004 09:54:44
 Re: Re: Torque Amplifier in reply to Greasy John, 01-27-2004 20:39:58
John, if you don't mind me asking, where did you find the eliminator shaft? I need to do that to my 350U, that way I don't have to worry about the TA screwing up any more. Thanks, Todd.
Kelly C
01-27-2004 19:48:22
third party image
Funny you should ask.
Here click on this link to my web site. When you get there look on the left pane find the link for Farmall 400 page. I have step by step photos of the one I just finnished.
