90 Weight Oil in Hydrostatic
SuperCmore
01-28-2004 18:54:02
Will 90 wt. gear lube make the hydrostatic in my 112L John Deere (sorry) garden tractor work any better?? It won't hardly pull itself up a hill, but of couse, it is a Deere. Can you get 90 wt. NON detergent?? Thanks, CMore
Hugh MacKay
01-29-2004 02:30:19
 Re: 90 Weight Oil in Hydrostatic in reply to SuperCmore, 01-28-2004 18:54:02
SuperCmore: No it will not work, best stick with the finest of hydraulic oils for hydrostatic especially. In the case of your machine I would go right to Deere. When I was farming I always found Deere hydraulic oils in a league by themselves. You fill a loader tractor any make up with Hy guard from Deere and the rams on the hydraulic cylinders will take on a shine you can almost see yourself in them. I know many logging contractors with heavy loading equipment, all makes. They will tell you Deere oil will improve performance and reduce repairs.
This goes right back to my old saying, I've yet to see the perfect tractor, but they all had some good ideas. The same applies to their parts and supplies.
