rear end noise on 706
casey
01-28-2004 19:17:25
help from all you smart guys! i have a '64 706 gas. i never noticed it back when it was warm (-20 here today) the rear end squeaks when i move it after start up. only at slow speeds though, 1-4 low. if i let it warm up enough and take off in high it will squeak for a short time and quit and not do it again. i'm thinking outer bearings on the axles. yes i have greased them and even while it was moving. thanks
Larry B
01-29-2004 06:33:00
 Re: rear end noise on 706 in reply to casey, 01-28-2004 19:17:25
Does the tractor set outdoors? Sounds like the brakes. The out side bearing would be poping when it turns. My 806 did the samething a few years back. Mine is inside in the winter but moisture still gets in the brakes from sweating and a little rust gets on them. Check after about 10-20 min. of use and see if the brake covers are warm. Could be the brakes set to tight
the tractor vet
01-28-2004 19:48:32
Now that is a new one to me and i have had every nut and bolt out of that seires tractor. Do like i do and let it get aquainted and then fix it that way ya know what went wrong. I am not tryen to be a smat arras this one has me stumped. It could be ice in a brake or even a seal squeek. . OR and axel bearing like you said , put a jack under one side at atime and hold the other brake .
