no oil on the rockerarms
k,james
01-29-2004 11:00:01
I have a TD9 w/ a 4cyl. I don't have any oil comeing to the top of the head. I don't know if I should. The push rods are solid. I know that is how my ford truck oils the lifter and cams. Another wierd thing is the oil pump. I have two manuals for the machine. They both show the same pump, but its not the one in the tractor. they show a somewhat side mounted pump w/ a small drive gear that i can't tell what it engages, but my pump bolts right under the crankshaft. the crank has a gear on it that drives a large gear on the pump shaft. Me real concern a this point is if I have proper lubrication for my valves and rocker arms. All advice is apperciated very much. God bless all! kenn, blythewood, sc
Aces
01-29-2004 12:34:00
 Re: no oil on the rockerarms in reply to k,james, 01-29-2004 11:00:01
Only worked on one w9 but I think you should have oil on top for rocker arms passage may be pluged.
jim in ny
01-29-2004 17:03:43
 Re: Re: no oil on the rockerarms in reply to Aces, 01-29-2004 12:34:00
did you by chance have the head off? don't know but you may have the head gasket on upside down I did this once on my 560. gasket fit fine except for the oil passage bloked off DUHH! make sure gasket is marked this side up is up!
