H fast 4th gear
brad
01-29-2004 11:22:48
I have an H farmall that Im looking for a fast 4th gear, sliding gear teeth count 29 and driving gear count 41. My H has the slower 4th with sliding gear count at 35. Can anyone help?
Thanks
Brad
870-919-1886
Charles Park
01-30-2004 08:26:24
 Re: H fast 4th gear in reply to brad, 01-29-2004 11:22:48
Wonder if JP Tractor Salvage might have the gear you are looking for. They are at: parts@jptractorsalvage.com
Hope this helps.
Jim
01-30-2004 01:17:01
I have my fathers 46 H on blocks waiting for me to work on and get it going again. My father bought it in about 1952. It had a 9 speed overdrive in it. A part broke and could not get parts. Put in a TSC kit. Moved the 3rd gear almost to 4th regular and 4th gear speed to about 11 mph. We used the 46 H for raking hay. Did not use much gas in 4th gear and half throttle. I just bought a stuck H last weekend with a 9 speed overdrive and a M&W live pto clutch. Do not know much about this tractor except that it is a 52. Contact me by e-mail with a phone number and your location. If I do not get the 52 H engine unstuck easily, I might consider parting it and selling the stripped drivetrain, differential and engine.
mercneck
01-29-2004 20:56:05
If anybody is curious, there's a "H" on ebay with a serial number ending in what I believe is "X9". That would also, according to my book, indicate high speed gears! The seller says serial number ends in "X9I". Think that's a typo though. Will find out shortly.
earlschieb
01-29-2004 19:41:52
They are correct, there was very few of the Farmall H tractors made that way, and I happen to have one of them, the faster 4th gear is a nice option. The way to identify one is by the last letter of the serial number, such as mine is, the last 3 digits are, X 1 F. Good luck in your hunt for the gears. Maybe when I get REALLY sick of this tractor, I will sell it. L.o.l. !
Jim in michigan
01-29-2004 14:07:31
Do you have a 5th gear in your H? Mine does....Jim
boob
01-29-2004 16:08:07
 Re: Re: H fast 4th gear in reply to Jim in michigan, 01-29-2004 14:07:31
mine has a 5th also but he asked about a fast 4th
very few made good luck
brad
01-29-2004 14:31:31
Well lets see 4th and 5th sliding gear is made together so yes I have a 5th, but 5th gear is to fast, and regular 4th is to slow. Im using tractor as a pulling tractor and want to get tractor as close to 12 mph and only run 2400 rpm. I believe regular 4th would put me at around 9 mph and fast 4th would be around 11. Isnt 5th around 15 mph at 1700 rpm? I was hoping someone could help me locate a factory "fast 4th" which was supposed to be 7mph at 1700 rpm.
Jim in michigan
01-29-2004 19:44:39
 Re: Re: Re: H fast 4th gear in reply to brad, 01-29-2004 14:31:31
Mine must have some high speed gears or something then,,, I get close to 20 out of 5th and roughly 12-14 out of 4th,,,Jim
scruffy
01-29-2004 20:01:18
 Re: Re: Re: Re: H fast 4th gear in reply to Jim in michigan, 01-29-2004 19:44:39
tire size changes speeds alot, factory specs are for 10x38, the taller the tire the faster ya go.
My H has 13.6 x 38 and I beleive road speed would be 18 or maybe 20 mph
Jim in michigan
01-30-2004 06:13:39
 Re: Re: Re: Re: Re: H fast 4th gear in reply to scruffy, 01-29-2004 20:01:18
I have 13.6 x38 on mine as well.. I took the rims and tires off of a junk M that I have,,,Jim
