Order Farmall Cub Parts Online
M 60 cub engine
randy J
01-29-2004 19:31:00
Can anyone tell me what model number tractors contained the M 60 engine. It is a 4-cylinder gasoline engine. I am looking for an oil filter and other miscellaneous parts. Palmer brothers converted it to be a marine engine with the designation P60. The engine was build in the early to mid '70s. It is rumored that the engine came from an IHC cub but I can not find a model number.
Thank you for any assistance
Bigdog
01-30-2004 07:12:08
 Re: M 60 cub engine in reply to randy J, 01-29-2004 19:31:00
The oil filter is:
IH 376373R91 AC P-321, Fram C-235
NAPA 1153, Wix 51153
Purolator L2008 or L2009
Fleetguard LF-672
NAPA will also have ignition parts.
Bus Driver
01-30-2004 04:52:20
Yes, that was the Cub engine. Made only by IH, but the engine was used as power for several implements and other manufacturers. Engine serial number is stamped into the left side of the block behind the carburetor.
