560 loader on other tractor
Chris Brown
01-30-2004 10:51:30
I have a 560 nf that I adapted a case loader to fit.The 560 it real tall and top heavy with this loader,will my loader fit any other lower tractors like a 660,is what I had in mind.A 560 wide front won't work because the axle sits to far foreward and my loader is set up to be real close , The bucket touches the front tires when the front of the tractor is barely lifted off the ground.. I would like it to bolt into the same holes or real close to the ones on the 560. The loader bolts onto the frame rails and has some brackets I made that clamp around the rear axle housings. I don't want to have to butcher the loader again to make it fit.Any other lower tractor suggestions in the $2000 price range that have similar shape and designs.
Jim in michigan
01-30-2004 11:04:36
 Re: 560 loader on other tractor in reply to Chris Brown, 01-30-2004 10:51:30
A friend of mine has a 560D Narrow front, it has a loader on it that came off of his dead JD B ,,it fit perfect with no changes,,,Jim
