IH 454 Hydraulics
Kenneth
01-30-2004 12:17:16
I have a IH 454 with a loader. The 3 point hitch will not raise until the bucket is activated. There is no auxilary valve on the tractor. I have been told that you must have an auxilary for the lift to work correctly but have also been told that you do not.
These valves are very hard to come by and when you find one they are very expensive. All i want is for the hitch to work. Any help would be greatly appreciated.
Diesel Bob
02-02-2004 11:20:58
 Re: IH 454 Hydraulics in reply to Kenneth, 01-30-2004 12:17:16
sound like your piston is stuck or tight in the unloader and flow control valve located on top of the hyd top cover
JB
01-30-2004 19:30:55
Hi, my brother has a 454D and 495D. The 495D is just a newer version of the 454D. He has a 2250 quick attach loader on the 495D and has no problems to use 3 pt., remote outlets and loader.
How is your loader connected to the hydraulics?
My brother's has the main inlet pipe to the loader control valves coming from a pipe plug outlet on the right side of the transmission under the 3 pt control lever. The return line goes back into the reservior under the seat. I just can't remember where it is connected.
If you require more detials, repost and I will check with my brother.
Good luck
JB
