IH DOZER
RICK
01-30-2004 16:16:00
my neighbor has a international dozer for sale.it has a 6 way blade and a winch on the rear also a diesel. looks about the same size as small john deere 350/450 (on this scale) he is asking $15.000 for it . is it worth it.thanks ill be waiting for some input.
Bruce Wa. d
02-01-2004 15:02:43
 Re: IH DOZER in reply to RICK, 01-30-2004 16:16:00
If it is a TD7 or 8 it will be a good machine. easy to operate with a 3 speed forward 3 reverse power shift and 4 cyl engine. for 15000 it should have a very good condition under carriage and the rest should be pretty tight. otherwise the price is too high. there were a lot of these made so that shouldn't be the only one around. If it is the smaller (350 JD size) model 500, don't buy it at any price. I have first hand experience with this. Very handy little machine with an excellent 3 cyl engine but it has dry type steering clutches and brakes that need constant attention. for every 3 hrs. using this machine you will be fixing some thing. Has a 3spd gear type trans with power shift reverser.
