806 LP Engine Size
Jim
01-30-2004 20:30:01
What is the size of the 806 LP, and can you convert this tractor to gasoline.
Kelly C
01-31-2004 06:11:02
 Re: 806 LP Engine Size in reply to Jim, 01-30-2004 20:30:01
Dont know for sure but I suspect you can. Should be just a manafold, Carb and a gas tank.
Save the LP stuff and switch it back latter.
That LP head should rev up the HP I would think.
F-man
01-31-2004 05:54:05
The bore and stroke of the LP 806 is 3 13/16 x 4 25/64 giving it a displacement of 301 cu. in. It is the identical size as the gas motor. The LP tested at 93.42 HP and the gas tested slightly lower. I'm not sure the of the details of converting it over to gas but I would think that this is somewhat of a rare tractor. Just curious, why do you want to change it?
