How close is a 544 to a 2544
gramps544
01-31-2004 12:21:41
I have a International 544 utility. What is different between a International 544 and 2554. Aren't they both utility tractors? Could a 2544 come as a row crop? Were all 2544 gear drives?
Also is there a location on the internet that list out the price differences in 1969 between a 544 International, row crop, farmall, and the 2544?
Harold H
01-31-2004 14:03:57
 Re: How close is a 544 to a 2544 in reply to gramps544, 01-31-2004 12:21:41
The 544 was built as a Farmall 544 (row crop) gear or hydrostatic drive, International 544 (utility) (gear or hydrostatic drive) and International 2544 (industrial)(gear drive, hydrostatic drive, or shuttle transmission). The International 2544 was the same basic configuration as the International 544 except it had a different standard front axle (the front axle like your International 544 utility was optional) and a different grille. Some other standard items were different between the I-2544, and the I-544 including tire types and sizes, but a I-2544 could be ordered with options to make it basicly the same as the I-544 utility. The International 544 was also available as a International 544 Row Crop which was the utility configuration with the Farmall type rear axles and wheels and a taller utility front axle. These options were not available on the International 2544 therefore the International 2544 could not be ordered as a row crop tractor.
I don't know where you can find the price differences.
Harold H
Gramps544
02-02-2004 09:59:18
 Re: Re: How close is a 544 to a 2544 in reply to Harold H, 01-31-2004 14:03:57
Thank you for your insite. Maybe you could shed some more light on this issue for me? I thought the industrial units were just cheeper versions of the more farm type tractor versions (Farmall and row crop). The utility front axle (which I have) is not adjustable. I wonder if they offered this axle due to the adjustable front end units not being able to handle a lot of weight up front (such as if a front bucket was up there).
The fixed rear draw bar is a real inconvience as I cannot swing my rear blade around with it on. The Farmall telocoping unit would be much better. I wonder if it could not handle as much load and that is why it was not a standard item on the utililty? Also the International 3 point have a separate stableize bars (which mine are long lost) where a farmal unit has locking lift arms. I always thought the stableizer arms were a after thought to the international 3 point hitch. You wouldn't know which tractors (versions) would have these stableizer arms?
I wonder how many utilities ended up on farms and Farmalls or row crops ended up on freeway crews and etc.
So really, a 2544 has the same platform as the I-544. It just allowed for more heavy duty options. Were 2544 painted yellow or farmall red?
Do you know why IH made the front wheel rims concave? I realise you can flip them for a slightly different tread path, but wouldn't the rim be stronger built more like a truck rim?
Sorry for the volume of questions, but I have not been able to find any good reference internet sites on the 544 model.
