606 trans
Lary
01-31-2004 16:03:42
My nephew has what I believe to be a 606 loader tractor that is stuck in reverse. His friends are giving him all sorts of quick fix ideas including towing it backwards, have any of you guys dealt with this prob.and if so how did you resolve it . any advise would be app. thanks in advance Lary
John
01-31-2004 18:18:40
 Re: 606 trans in reply to Lary, 01-31-2004 16:03:42
sounds like the shifter is wore. on ours if you take a light and look where the ball of the shifter rides in the slots you can usually take a screwdriver and slide the odd shift slot. if all of the slots are aligned there is a problem internally
Lary
01-31-2004 20:21:07
 Re: Re: 606 trans in reply to John, 01-31-2004 18:18:40
John;Are you describing something sim. to what we used to do to an M when it got into two gears? Lary
John
02-01-2004 13:15:13
 Re: Re: Re: 606 trans in reply to Lary, 01-31-2004 20:21:07
yes, similar, but it sounds like in your case that the shifter has slid out of the reverse slot without moving the slide.
