Just got a 140 and was wondering...
Stoneynsc
01-31-2004 16:10:18
If anyone could let me know the recommended fluids and capacities. Also if it's ok to use regular antifreeze. I've only run the tractor for a couple hours today but noticed that everytime the governor starts to open up under a load the engine starts loping. Anything I should know before I start tearing into the carburator? Thanks
Stoney
Jay
01-31-2004 19:36:27
 Re: Just got a 140 and was wondering... in reply to Stoneynsc, 01-31-2004 16:10:18
Crankcase - above +32F - #30 preferred, 15w40 acceptable. It holds 5.5 quarts with the filter.
Transmission & Differential - HTF meeting spec. MS-1207 (hydraulic oil) HyTran, Mobilfluid 424, Chevron 1000 fluid, etc. - it holds 4 quarts in the transmission & differential - it holds 4.5 quarts if it has a PTO - it holds 5 quarts if it has both a PTO and a belt pulley.
Final drives and hydraulic system use the same HTF spec. Final drives hold 1.375 quarts EACH. Hydraulic system holds 3.375 quarts.
The cooling system holds 15 quarts. I don't believe it requires any special anti-freeze there.
Fuel tank - 11 gallons.
Stoneynsc
01-31-2004 20:57:42
 Re: Re: Just got a 140 and was wondering... in reply to Jay, 01-31-2004 19:36:27
Thanks, that's a big help.
Robert
01-31-2004 18:38:07
Winter temperatures, light load, high intake manifold vacuum, loping or surging when governor opens up, sounds like a classic case of ice buildup interfering with movement of throttle plate.
Commonly known as carburetor icing. Check out that possibility before you disassemble anything.
Haas
01-31-2004 17:54:57
Likely the loping engine is the governor, not the carburetor. The bumper spring on the governor probably needs adjusting. You need to get a sevice manual from Binder Books.
Stoneynsc
01-31-2004 20:58:59
 Re: Re: Just got a 140 and was wondering... in reply to Haas, 01-31-2004 17:54:57
Many thanks, I'll definitely get the manuals.
